I have been using 2.22 for while now.. I wanted to upgrade... but when I install newer versions... the text which shows what is in the fields on the right side is all invisible (or white). Why is this and how can I fix it so that I can use later versions....
Close Mp3tag.
Press [Windows-key + R]
Enter: %APPDATA%\Mp3tag\data
In this directory, delete the file columns.ini
Start Mp3tag again.
And please make your signatur picture smaller or remove it.
Thanks! Worked like a charm.
