We used to be able to edit the Title field on the right hand side and not in the Tag Panel sidebar. Can this feature be re-instated. It made for editing batches much easier.
Thanks
Thanks
It still works. Click on a line in column view to select it, then double click on the Title cell.
I've done that. I can change the title, but when I press Enter, the title is returned to what it was previously.
OK. Open the Customize Columns dialog and from there look at the Title options dialog. Verify that the value for Field in that dialog is %title% (see screen shot below). Without that value, the field is read-only in column view.
Thanks a lot. It was set to %TABL%
Then take a look at the files that you tried to edit in this way using the extended tag view (ALT+t).
You will surely find created tag fields with the name TABL.
