Allowed characters in filter searches? How quoting within expressions work?
What characters are allowed within the quotes. For example, I've tried filtering for this tag:
  • genre HAS "Kick+Clap/Snare" & `genre HAS "Kick+Clap/Snare + ?"
    And I was getting results for the latter genre in the first.
It clearly didn't work so then tried Kick-Clap_Snare & Kick-Clap_Snare+? to no avail.
This also occurs with searches like: genre HAS "bounce" yet showing results with "Melbourne Bounce"
Am I misunderstanding how mp3tag filters?
I think that this is no valid filter syntax.
I would say that the string "Melbourne Bounce" contains (has) the string "bounce" - so everything is fine.
The shorter the string and the further it is from being unique, the more matches you get.
This is a substring filter, showing every file that has Kick+Clap/Snare in one of the genre fields. This means that it can also contain more text around the search string, e.g., Kick+Clap/Snare + ? which has an extra + ?
If you want an exact match, use genre IS "Kick+Clap/Snare"
Of if only that complete string is to be matched and not
then append the filter expression to
genre HAS "Kick+Clap/Snare" AND NOT genre HAS "+?"
But that means it will only match if genre tag only has that string?
Thank you, this is an ingenious trick!
