Alternate Export Options
Is it possible to export to .mdb or .dbf?
Currently, I export to .csv and then use another program to change the format to .mdb or dbaseIV (I need the data in both forms for use on my website and in a personal database program).
Thanks in advance for any help with this.
RICK
It is not possible to do so at the moment, AFAIK.
Yes, this is not possible and Mp3tag won't support these formats, because they're not text-based.
Best regards,
~ Florian
