Hi, is it possible to exclude some of the 'Additional Info' that is pulled from Discogs. For example not write the 'Media Type' or 'Country' info to the tags?
Thanks, Bruce
Thanks, Bruce
Web source scripts are plain text files, so you can edit them yourself.
use the comment character # at the beginning of each line which instructs to write information that you do not want to "comment that statement out".
Then save the script.
Thanks. I just realised I was editing the right script, in the wrong location.
C:\Program Files (x86)\Mp3tag\data\sources, instead of:
%APPDATA%\Mp3tag\data\sources
Appreciate the prompt response
