Could someone please tell me: is it possible to change multiple tags within MP3Tag at the same time? For example, if I want to change the tags on all songs in one album with one command, ho do I go about this? I have tried highlighting them all and entering a new album name, but only one at a time is changed.
This seems like something pretty simple, but I have trawled through the various commands and help sections and drawn a blank!
Select the files via the CTRL+LMB (left mouse button) to selectively select items or SHIFT+LMB to select from one row to the next or ctrl+A to select all.
Once you've done any of those, in the tag panel enter in the info you want and hit CTRL+S for a save.
OPTIONAL: In the options for Mp3tag go to Messages>untick ( after save & after change)
This will not pop up any messages.
Cheers,
Thanks for asking this. It has to be the most basic question yet, after using this software for a year or more, I had no idea how to make the tag panel work. It looked like a simple intuitive feature yet nothing I did worked so I gave up on it until now when I needed to make a bulk change.
As soon as I saw your title, I figured you wanted to know the same thing. A simple press save to write changes under the panel would be a welcome addition for others.
