Any chance to add values to dropdown lists to fields
Hi all,
I was just wondering if is it possible to add dropdown lists to fields that we choose ?
Relase;
Studio, EP, Compilation...
Thanks all,
See this thread: /t/18317/1
Genre is a bad example as that is the only field for which there are standardized values. All others are free (with the exception of types of embedded pictures).
Guess you mean something like this..
I want to do it via tag control panel
Thank you anyway :slight_smile:
