any problems with freedb2.org?
Is there any new problems known with http://www.freedb2.org/?
Copy and paste of ID very often doesn't work. 74f754f6 I set enter manually, paste ID and set to rock but ID still not found.
(1• rock/74f754f6 Cocteau Twins • Head Over Heels)
Some IDs work and others don't. Looks like some new incompatibility arising.
Or is now possible to return to initial freedb.org?
version 2.36 a
Update Mp3tag to latest beta.
Only the web search was down, but the 3 other methods were always working.
Thanks for the suggestion.
Do the earlier option settings remain the same when upgrading?
I have set several rare options to mp3tag and I don't remember where and how ...
that's why i', afraid to upgrade ...
The settings should automatically be transfered, yes. I never had problems updating.
