Any way to create a Playlist?
I want to drag and drop files into MP3Tag to create a playlist, but each time I drop a file, it removes the current one and loads the new one - I want to add files indivudally?
Any way?
Press the Ctrl key while dragging & dropping.
In the file list use the Alt key to move the files to the preferred position.
I ended up coding a drag and drop app, let's me randomise the list too. May build on it :grin:
This function is also available in MP3tag:
View>Sort by>Randomize
The playlist itself is created with the functions from the File menu
