I find that TC with the anytag content plugin treats the "duration in seconds" as a string rather than a number. If I need to show all tracks with a duration of say less than or greater than a particular length, I can't do it easily. If it was a number I could see the < and > options. Is there a way around this?
Maybe ...
See file "...\TotalCmd\Plugins\wdx_anytag\anytag.any".
Find entry "13=8|Length (in seconds)|%_length_seconds%"
Change this entry to:
"13=1|Length (in seconds)|%_length_seconds%"
Hmmm... I found this solution too, but after half hour trying myself - I couldn't find this topic before; and TC's page doesn't has info about it, too.
Yes, suggestion to Florian: please include this info into anytags ReadMe.txt.
Keywords for others: Total Commander, anytag, find files: plugin, compare operations, larger, smaller, equal, treat as number.
