Anytag.wdx newer version than v100?
Hi there,
I found this plugin for TotalCommander, as I need to have a way to see play length of screen recordings, as the file size is not always accurate.
After long search and dead-ends leading to totalcmd.net - I finally tried using the Mp3Tag for TC. (anytag.wdx v1.00).
This works somewhat great - I can get my custom column with Length added, in good format - hh.mm.ss, so really happy with that.
But unfortunately it seems it is constantly trying to reconnect to my network drive with this one added, so I may not be really able to use it :frowning:
Is there any known issues with reading network files, causing TC to ‘reconnect’ constantly?
Would I need some sort of caching enabled for this plugin? - Maybe a full install of MP3Tag?
I know we are in a world where Total Commander may not have a significant impact anymore - but on the other hand, do mp3 files? :smiley:
I’d really like this to work for what I need it to, so if anyone know a better/more simple plugin to just get ‘length’ of video, I’m listening… If there are any requirements I have missed for the anytag.wdx v1.00 to work, I’m happy to learn new stuff!
In any case, thanks for reading this topic - have a wonderful rest of your day!
Tiroha
Yes, v1.00 is the latest version.
As for the network access, this should only happen if you browse the network share from one of your tabs in TC.
