Basically, I want to select music files in MediaMonkey and open those files in MP3Tag.
Thanks!
Thanks!
What about drag from MediaMonkey and drop into Mp3tag?
Hot damn! That actually worked! I'd still prefer a keyboard shortcut or context menu option, but this will work for now.
Thanks again!
I'm not sure if copy (CTRL + C) from MediaMonkey and paste (CTRL + V) into Mp3tag would work too...
Unfortunately, that didn't work. I'm going to try it from My Computer in MM.
had the same question, and yes, it's possible (kontext menu option) with a little addon/script:
https://www.mediamonkey.com/forum/viewtopic.php?f=32&t=99795
