I'm trying to append the Length of a track to the end of the file name in minutes and seconds.
I am creating a Format Value action with the field _FILENAME and the Format string
%_filename% (%_length%)
This does the job , but mysteriously removes the colon separator which is between the minutes and seconds in the Length field. I don't know why this should be. This squashes the minutes and seconds together , making it useless. Can anyone help , as i can't seem to fix it?
Instead of Filename (Mins:Secs) , I getting Filename (Minssecs).
00_42 will show as 0.42
05_05 will show as 5.05
13_21 will show as 13.21
This seems to work pretty well for me as a part of my Tag - Filename conversions, this helped to replace an additional Filename - Filename conversion that I ran to change the %_length% delimiter to a period and remove the leading zero for songs that were less than 10 minutes. Otherwise, I would just manually change the underscore for songs greater than 10 minutes.
