Artist different than Album Artist
Hi all,
How to use a filter to check/control whether Artist field is different than Album Artist field / or they match
Besides that i would like to also check if a given specifi field has a space at the ending like "Band Name "
Thanks in advanced
Check for equal names:
"$if($eql(%artist%,%albumartist%),1,0)" IS 1
or set the IS 1 to IS 0 for names that are not equal.
Check for leading or trailing blanks (example for artist field:
"$if($eql($len(%artist%),$len($trim(%artist%))),1,0)" IS "0"
Edit: added "not equal" description
I simply jus can't thank you enough :slight_smile:
Windows Media Player has started moving folders around. It has also added a second featuring artist to some of the tracks tags, which weren't present before!
Tried:
"$if($eql(%artist%,%albumartist%),1,0)" IS 0
"$if($eql($len(%artist%),$len($trim(%artist%))),1,0)" IS "1"
Worked:
Thanks.
