Artist from a part of the directory with regex
I have around 10.000 files that i want to organize. I am trying to fill the artist tag with a regexp expression that matches a part of the directory path. But nothing i try seems to work...
The folderpath is: D:\topfolder\subfolder\artist\album\
these are my settings in the replace with regular expression action:
Field: ARTIST(also tried %artist% btw)
Regular expression: $regexp(%_folderpath%,^D:\topfolder\subfolder\(.?)(?:\(.?)(.*?))?$)
Replace by: $1
I have tried quoting like this '^D:\topfolder\subfolder\(.?)(?:\(.?)(.*?))?$' but that is not working either...
I tested the regexp on regex101.com with ' as a delimiter....
What should i do to get this to work?
There is the function Convert>Filename-Tag.
You could try:
Format string: %artist%\%dummy%\%dummy%
or
Format string: %artist%\%album%\%dummy%
If you want so see more about regular expressions in MP3tag, have a look at the help:
A good test environment to test your expression would be the function Convert>Tag-Tag.
Also, I think that the $regexp() function is invalid in the action "Replace with regular expression)".
Ah, thank you very much. That's much easier!
