First of all, Mp3tag is a fantastic tool, and I use it very often.
But strange things happens. If I add a jpg-file as cover art, the size of the cover art is twice as the original size when the job is done. If I ad a 50 kb jpg-file, it ends up as (about) 100 kb when I use Mp3tag for the job. If I extract the the cover art from the flac after I have added it, the file-size is twice as the original.
But if I use for instance dBpoweramp edit tool to add the jpg-file as cover art, the file-size ends up with the same size when i extract it from the flac. All this happens also for other formats (mp3, m4a, etc.
So how can i get the original file size for the cover art, also when I use mp3tag?
I use the latest version of mp3tag.
Thank you in advance!
