I can't find a special character.
I have a table looking someting like that in firefox (I know it's not very well made!!):
| Auralux | CD | #LUXXCD 015 | 2005 |
| Auralux | LP | #LUXXLP 015 | 2005 |
|||______||
so I import it in text editor :
It appears like that :
Auralux [space] [tab] LP [space] [tab] #LUXXLP 015 [space] [tab] 2005
I'm not sur about the tab. But I think it is...
After I import it in a field in Mp3tag
and it appears like that :
Auralux £CD £#LUXXCD 015 £2005
£ is for square.
I could change the squarre for carriage return with this expression :
$regexp(%TEMPORAIRE%,\r\n,|)
r & n are the ascii charcter for carriage return.
So I tried to do that to remove the tab character :
$regexp(%BAND%,\t,%)
t is normaly the horizontal tab character
But it doesn't work. It just said :
Auralux [ SYNTAX ERROR IN FORMATTING STRING ]CD [ SYNTAX ERROR IN FORMATTING STRING ]#LUXXCD 015 [ SYNTAX ERROR IN FORMATTING STRING ]2005
So I don't know what I should do... Can you tell me please.
Thanks a lot
