HI,
Awesome ap. Thanks so much for putting on the Microsoft store!
When pulling disk information... there is no way to ensure the correct title/Tag info goes with the correct track when there are multiple disks.
i.e. I only wanted the second disk of a set. When I pulled the info from discogs, it would only apply the tags from the first disk to those tracks. The easiest fix was for me to delete the files and rip both disks in separate directories,
Rename all the second disk files so they were in order when put in the same directory.
And then tag them with Mp3tag. V3.03.
At some point would you add the ability to associated track on computer with track in the DB?
