Audio files not recognised
Last version problem?
So, right click to action mp3tag from a top level folder containing folder with audio files
No files selected
Enter that folder, select all - and they are recognised.
Do you read subdirectories?
That's an option Ctrl-O > Directories
Hmm. Never used that option. Never had this problem - using for some years. If it was set, it's not now. Problem still there
Could you show us a screenshot of the lower right MP3tag window to show us the status bar after you have opened the folder
E:\torrents\seeding\_GDH
like this:
grafik
OK. This time it's read them. Last time, I selected the top level folder, then changed the option. No changes. So must not have been recognised until re-reading the folder structure. Tiny bug maybe (25 years I bod) but no big deal.
Does seem that the last time I downloaded the program, this happened, as given I have always been able to see subfolders, have never thought there might be an option. Any all well - many thanks
