Now that we can work with WAV and AIF files
, I've noticed a minor issue when displaying WAV audio properties.
I have columns to show Codec, Bit Rate, Bit Depth, Sample Rate, Mode, etc.
I work with files which get rendered from a DAW at 32-bit (floating point) / 96kHz WAV and/or AIF. The columns mentioned above are populated correctly for AIF files with this format, but for WAV files, they are all blank. The issue appears to be with 32-bit float files exclusively, as 24/96 and other variations display as expected.
This is by no means a show-stopper, because the tags can still be edited, but I use those fields to sort files, so am hoping it could be addressed at some point.
Thanks!
