next the Player gives
Disc 1 track 02
Disc 2 track 02
etc. ...making the playback useless
The solution is to Tag these files so that the book will be recognized correctly to play the files sequentially through the Discs in order. I have spent many hours trying to figure out how exactly to accomplish the correct Tagging and have failed totally. I am the firsr to admit I am a novice in Tagging.
There are more than 100 files in a typical book of 12 CDs. Would you please give a step by step procedure describing exactly how this process can be automated to make the Tagging practical, so I can listen to the audiobook.
I will be happy to donate to show my appreciation!
You may rename the ALBUM so that it carries the discnumber at the end. This should make the album unique.
Or use the track numbering wizard with an unchecked option to reset the counter for each folder.
This would renumber all tracks in sequence from the first to the last track and avoid the ambiguity of having the same track number twice (or more) in the same album.
You enter the discnumber and use it as prefix for the tracknumber:
disc 1 track 1 = 0101
disc 1 track 2 = 0102
disc 2 track 1 = 0201 etc.
All except the setting of the discnumber can be done with actions or other functions in MP3tag. And even finding the discnumber is possible, if the files are stored in separate folders with a number in the name.
