Hi Florian,
I just was in Programming some actions
I am am using a Tag SOLOISTS and a Tag SOLOISTS_SORT (non standard on purpose)
Part of the action is a command
format TAG
Tag SOLOISTS
(any Formatstring)
everytime I use COPY or EDIT on this command line
the TAG changes to SOLOISTS_SORT
without me doing anything
(this is apparantly becuase the focus enters the field automatically)
this is quite annoying that when you just want to edit
the formatstring and you forget to control the tag entry
that it corrupts your whole action.
Surprisingly I have this constellation not with all my entries
sometimes the autofill prefers the shorter TAGname
like
COMPOSER is preferred to COMPOSER_SORT
ARTIST is preferred to ARTIST_SORT
but same problem with
ALBUM_ARTIST_SORT is preferred to ALBUM_ARTIST
(ALBUM_ARTIST beeing non standard on purpose too)
So please no AUTOFILL on Edit or Copy commands
or at least no Autofocus on the TAG entry.
When entering the command
amendment:
I just discovered that those two TAG names wich cause the problems
do not appear in any dropdown list with tag names
how can that be ? Can I write them there manually ?
