Hi...when I Select a folder from Mp3Tag, I then have to click "Select Folder" button on right bottom. Is it possible to open this folder automatically, so I DO NOT have to click the Select Folder button"
Looked in Help, but do not find this option. Thanks
You can go to "Options > Directories" and choose a favorite directory. If you want Mp3tag to always start in this directory, enable the configuration option "start from this directory".
Besides that, Mp3tag remembers the last directory you've worked in and tries to start from there the next time you open it.
