Hello
Can you make a check box for import artwork from inside folder mp3 files?
Take a look at iamage
Thanks
I would never want to get that done automatically. Unless you set WMP to strange values in the registry, WMP will resize already existing cover with better dimenations to tiny pictures with just 200x200 pixels - and I would not want that picture imported into my files.
What you can do instead:
filter for files that do not have an embedded picture with
%_covers% MISSING
Select these files.
And then use an Action (Quick) of the type "Import cover from file" in which you set as
Format string: folder.jpg
