I have come across a bug which is still present in the latest build (V2.36).
For this bug to be reproduced the Track field should be empty at the start.
Steps to reproduce.
- Use the auto- numbering wizard to number the files. (The track numbers appear correctly after this operation)
- Right after the this edit the "Comment" field in the main window. The track numbers disappear. (Any editing of the Comment field erases the track numbers)
