Hello!
I honestly cannot see the point in hiding the auto-numbering wizard in the "Convert" menu.
Instead of reducing the number of clicks needed to perform a function, it has been chosen to do the opposite so now mp3tag is a bit more user-unfriendly.
The program is amazing, but the UI has been long needing for an optimization... and this is not it.
Yes, it is the same number of clicks as before - but the function is far from being hidden. The menu item is clearly visible.
And if you use the button in the toolbar it is just 1 click ... so nothing has changed except that the developer has to maintain 1 menu less.
Exactly:
And if someone prefers a keyboard shortcut: Ctrl+K
