I was not sure who the person called “poster’ was or what his role is. Was not sure whether he was trying to help or what.. as when he wrote “No. I don't doubt that this is a screenshot from your PC.” I misread it as “I doubt that this is a screenshot from your PC.” as I guess I was watching TV at the same time and did not give it my full attention.
But on re reading I do apologize.
I simply rip my CD’s using DBPoweramp..store the uncompressed FLAC on my hard drive. “Massage” it with mp3tag to add/ correct composer info or typos, do auto numbering etc.
The I create copies in FLAC Level 5, ALAC and LAME from the FLAC Uncompressed using dbPoweramp Batch Converter.
I usually then have to do auto re numbering on the FLAC Level 5 version as it doesn’t carry across from the FLAC Uncompressed.
If at a later date happen to make a change by using windows explorer I usually have to check that it did not affect the track or disc numbering and if it did redo it.
But in future I guess I will just use mp3tag.
I also took it that any changes made outside mp3tag with regards to the issue I was experiencing needed to be corrected by using mp3tag after I changed it using windows explorer. And I am fine with that if that is how it has to be.
When I look at properties of my files using explorer with Win 10 Pro 64bit I get exactly the image that I added..no other program(s) are involved..just highlighting the track or tracks ..right click with the mouse and select properties..go to ID Tag and I get:
The right side is just the second screen that go included in the Print Screen.
I do not see an image like:
And I was under the impression from some of the other posts that if I made a change in anything other than mp3tag then I had to perform more steps in mp3tag and just live with it.
To me the scenario is easily reproduced and I’ve been working around it for a long time.
If you think there may be a “fix” that would be great but if it is the way mp3tag works and nothing can be done that’s fine also.
Maybe I’m the only person who bothers doing this with track and disc numbering and correcting composer info etc etc..got to get a life..
Did not want to get into any angst over it..getting too old for that… and I did appreciate the help offered.
Thanks
