I have been using Auto Numbering Wizard to do my track and disk numbering.
track numbers are in the form 01/12 disc either 1/1 or 1/2 etc.
An issue I seen to have is if I make any changes using mp3tag to say album artwork or correcting a typo in the metadata I always have to re do the Auto Numbering Wizard.
Am I doing something wrong or is this the way its expected to work.
The autonumbering wizard writes the tracknumbers/discnumbers to the corresponding tag fields. Once they are written and you change another tag the files do not loose the content of these tag fields and there is no need to run the wizard again.
How do you make these changes? (Tag panel?, Web Source?)
If reverts that could mean that is something with Flac specific. Wait for @Florian or @ohrenkino to comment on this, as my knowledge is limited about this
Have you checked if the track numbers were really written with a leading zero when you first applied the wizard? Is "Leading zeros ..." checked in the wizard?
Are your files really flac-files? MP4-files for instance don't allow leading zeros, flac-files do.
AFAIK FLAC has a separate field for TOTALTRACKS.
So the initial data from TRACK is split (by some other program?) into TRACK and TOTALTRACKS.
(Please check the extended tags dialogue Alt-T to confirm)
This is file format specific (like e.g. mp4 tags do not allow leading zeros).
In the tag panel you would have to add an object for TOTALTRACKS.
In the file list you can emulate the initial display with
Value: %track%[/%totaltracks%]
You can still use the numbering wizard. MP3tag then takes care to store the data in the format specific, correct fields.
Not sure I’ve explained my prob properly.. But to simplify I just reproduced using 1 album of a double album
I simply used mp3tag’s track number wizard to number the tracks 01/19 to 19/19 Discnumber was 1/2..saved it. I then opened the whole album in the windows file and changed the album front cover. Went back to mp3tag.. refreshed..and the track numbering changed back to 1 to 19 and the disc number was 1. (ie No longer 01/19 to 19/19 Disc number 1/2)
Not really involved with total tracks I don’t think but track total in Alt T was 19.
Simply highlighted all the tracks..right clicked went to properties..used choose album art from the internet..just chose another cover..hit apply..went back to mp3tag hit refresh.
If a remove the cover in mp3tag and add the cover from the folder.jpg using just mp3tag the track numbering does stay in the correct form. trouble is that mp3tag does not let me scan the web for another cover like I can in the properties are the music file on the hard drive.
So do you consider the actual file on the hard drive as another program?
