Auto replace special characters in the filename?
Is there any way to "auto replace" the characters instead of having to manually replacing them?
For example the title of a song is "17. Not Alike (feat. Royce da 5'9")"
But it will give me an error that i cannot name it that so
I will have to manually edit it to be "17. Not Alike (feat. Royce da 5'9_)"
You can use the $validate() function when you create filenames from tag, e.g.
Format string: $validate($num(%track%,2). %title%,_)
Or, if you want to have your own preferences, e.g.
Format string: $replace($num(%track%,2). %title%,",_,*,_asterisk_)
I meant on the main interface and not when exporting track lists,
where would i add the function?
Yes, that is what I also meant and I thought you referred to the function
Convert>Tag-Filename
Thank you again! A life saver :heart:
