Ok, here's my 2nd question.
Many of my old ripped CD folders lack the year, unfortunately.
Is there a way to auto-fill in the year in all files without changing the rest, by calling up an action or something ?
Thanks for any help,
susiwong
you can take one of the many existing web sources scripts in the forum and edit it to write only the year.
open it with a text editor.
EASY WAY:
write at the end of the script:
set "artist"
set "album"
set "tracks"
for every tag you want to keep untouched. important: use "tracks" instead of "track" & "title".
MORE COMPLICATED WAY (but maybe the script runs faster)
delete everything in the script which is does not belong to the year tag.
keep only:
the index part of the script which finds the album in the web.
the necessary parts to find & write the year.
keep everything above "[ParserScriptAlbum]=..."
replace everything from "[ParserScriptAlbum]=..." to the end with the following code:
# A L B U M
# Uncomment the following line if you want to write some debug output
#debug "on" "c:\\\\debug_freedb2_B.html" "10"
# Year
findline "DYEAR="
findinline "DYEAR="
outputto "Year"
sayrest
save the .src file under a new name, e.g. freedb2_b_YEAR_ONLY.src to keep the old file if needed.
