I will always use mp3tag in this way:
- right click on album directory and select Mp3Tag
- then the first thing I have to do, thousands of times so far is "Edit" menu, "Select All Files" or I do a Ctrl-A
I KNOW, many have their reasons that we should browse for files within Mp3Tag, but this way works for me and MANY OTHERS here.
Could it just be a simple option that is "off" for your defaults, but the rest of us to put a check mark in "Automatically Select all Files at program start"?
I have never had a problem with tags, or issues by starting my mp3 session with a right click on the directory. If this is such a problem with the not recommended way, then why don't you get rid of the right click?
Thanks in advance, don't get me wrong here.........there is NOTHING like Mp3Tage and I will continue to use it.
