Auto Tagging Artist and Album Artist the Same
This has been asked in various forms but I couldn't find any solution specific to this.
I just want to tag all of my files by using the same entry in both the Artist and Album Artists fields by using the Filename - Tag tool. I can do one or the other, but I want to do both at the same time. All of my files are Artist - Title.mp3
as this has been answered just 1 day ago:
the answer has not changed.
Using a action group with 2 subsequent actions does this job for the user
I really don't understand that. I'm reading the Help page and every Action setup I've tried doesn't work.
Wouldn't then a subsequent application of Convert functions be the safer way?
First you import the data with Convert>Filename-Tag and
Format string: %artist% - %title%
and then copy the contents of ARTIST into ALBUMARTIST with Convert>Tag-Tag for ALBUMARTIST
Doing it with actions could be done with an action of the type "Guess value" with
Source: %_filename%
Target: %artist% - %title%
and then a second action in that group but this time of the type "Format value" for ALBUMARTIST
That's exactly what I was trying to do. Thank you.
