Auto taging Label info?
I can use a "tag source" to get a Label info, but is their a way to have it only put the Label info? And can i tell to put the Label info into the "contentgroup" field?
Thanks!
my discogs script can do that
/t/9226/1
when you are at step 6 of the installation guide there, use the following settings:
DISCOGS_LABEL = contentgroup
all other DISCOGS_... fields = no
DISCOGS~TRACK_OPTION: LEAVE TRACK EMPTY? = yes
DISCOGS~TRACK_OPTION: LEAVE MASTER TRACK EMPTY? = yes
you can choose how to deal with more than one label in this field:
TEXT OPTION: MULTI LABEL: MULTIVALUE TAG (= YES)/ONLY FIRST (= NO)/SEPERATE BY: (WRITE CHARACTERS)
Thanks, I think I set it up correctly but I am confused as to how I execute the script...
I haven't used web-scripts before.
tell me what confuses you and i will help you.
my script is a little bit more confusing as the other ones here in the forum. all others are just ready to use src files. i have made this settings-mp3-file/export trick, so everybody is able to edit the scripts.
ah, I got it working! I actually hadn't set it up correctly.
Thanks for the help!
