Hi all, im starting a new thread with a followup question based on garym's recommendation.
As the title suggests im creating folder structures from my tags and am going for the structure of:
For single or 2 disc albums:
%Artist%/%Album%(with year(if applicable))/%track% - %title
For albums with 3 or more discs:
%Artist%/%Album%(with year(if applicable))/disc#/%track% - %title
This is what ive got so far:
C:\Music\%artist%\%album%$num(%track%,2) - %title%
Just stuck with how to edit this to do what i want - hope i made this clear.
Was also wondering if it is possible to detect if discs of the same album are called something different ie:
disc1: SH1-sounds
disc2: SH1-noise
As in these are the same album but the discs are called something seperate so i want the album to be SH1 with 2 discs inside the folder called sounds and noise.
Think this may be too much to detect automatically so i think this may be something i have to do manually.
Hi dano - thanks for the response. That dosn't quite achieve what i was looking for.
I mean if there are 1 or 2 discs all tracks are put here:
artist - album - tracks
however if there are 3 or more discs put each track for each disc in a corresponding folder:
artist - album - disc1 folder, disc2 folder, disc3 folder (each folder containing corresponding tracks)
After using this on a 4 disc album i got this:
Artist - album - tracks (for disc 1 and 2) and 2 folders called 3 and 4 containing the tracks for disc 3 and 4.
You are right. I overlooked that we need to check the total disc count.
So the question is do you have that info saved in a tag as well?
Like Discnumber = 1/4 ?
Hi, i was wondering if you could help me make a small change to this:
C:\Music\%artist%\%album%[ - %year%]$ifgreater($regexp(%discnumber%,'^\d+(/|$)',),2,$num(%discnumber%,1),)$num(%track%,2) - %title%
In the \%labum% section is it possible to say if you find a ":"(without quote marks) replace with a " - "
Just because windows wont allow for ":" so when the folder is created it would be better to replace it with a " - " Is this possible?
have a look at the $validate function.
if you want to be sure you could modify the mask like this:
C:\Music$validate(%artist%\%album%[ - %year%]$ifgreater($regexp(%discnumber%,'^\d+(/|$)',),2,$num(%discnumber%,1),)$num(%track%,2) - %title%)
