Automatic replacement of TITLE when using an export action
I use this script for exporting a list of files
$TITLE(C:\Users\YOUR-USER-NAME\Documents\! Mp3tag export list %_DATETIME%.txt,utf-16)$loop(%_filename%,1)>> R + E ~ >| - %TITLE% $loopend()
Would it be possible to automatically replace something [if it it present] to something else?
For example among all of the files loaded to Mp3tag and selected for the list creation there would some files that would have [all of those some files] a title like
A (B) {C)
but I would prefer to see in the TXT file
X [Y] #Z
every time [thus such exchange would happen often many times]
Right now I have to make such replacements manually within the TXT file; which I do often and repeatedly for the same TITLEs, which is both time consuming and plain tiresome
The export supports the scripting functions (take a look at the help file), hence you can use commands like $replace(string,from,to) to change the output.
Example:
$replace(%title%,'A (B) {C)','X [Y] #Z')
