I'm a newbie. And I can't figure out why when I select more than ONE file then using the MENU item > TAG SOURCES > freedb > determine from selected files> I get the ERROR "No Suitable entry found for freedb ID 2c02d807.
I have a ton of files to tag. It only allows me to do the above action if I ONLY select ONE file at a time.
Please tell me that I'm doing something wrong because I can't imagine this program cant scan and tag files in a batch fashion. Thanks, bob
Just to be clear, the Tag Sources are designed to tag one album at a time, not an assortment of files from various albums.
For successful tagging using "freedb > determine from selected files", each and every track of 1 and only 1 album must be selected and they must be in the correct order in Mp3tag.
It seems as if this search relies on the number of tracks and their length and/or order, without regard to metadata or filenames.
I'm tagging my collection for a long time, album by album, year by year...it' long process if you want to make it right.
Literally, if you have large music collection and you want to make it right, that's really long process and it can take you few years.
I have few versions of same albums (LP, CD, web downloads, reissues, limited editions, original releases etc.) and I don't know if any tag app can make that right in one go.
Maybe MB Picard can do that but you can't get 100% correct results for all albums and again you will need to check all albums before writing tags in Picard.
