Thanks. I tried that but its not pushing over the exact format. Meaning, for the filename Serum & Serial Killaz it shows in Artist as Serum And Serial Killaz, it doesnt seem to want to copy over the '&'.
Your wish was to create a new filename, not to get artist and title from the filename. In your example the tags for artist and title were already o.k. and needed no change.
Therefore I wrote a link to the help-file for the converter "Tag - Filename" and not for "Filename - Tag".
Did you use that?
And what format string did you use?
The right one should be
%artist% - %title%
