I'll just bet that this is a simple oversight on my part, but I'm having a tough time figuring out how to enable or add a column for the BPM (Beats Per Minute) field. Can someone clue me in?
(I'm using Mp3tag v2.36a.)
Thanks!
Thanks!
To open the Columns dialog you may use the RightClick menu from the column header in gridview,
or you may use the menu items View/Columns from the main menu.
Once you've got it, you may see something like the following window.
Use the dialog buttons to insert a new column, fill the other attribute fields, use it.
DD.20061013.1515
