Please don't suggest Nero or ImgBurn. Really.
I haven't burned an audio CD in years. Used to be into it like a fine art or something. I've hoped things had changed, but it seems the backbone of most every program I see is data backup.
Is there anything remotely close to Feurio! in terms of raw capability when burning an AUDIO disc?
It's not that I'm against using Fuerio!, but that I'm wondering if anything decent has appeared in the past decade.
If you don't know what Feurio! does that others do not, imagine being able to control where and how every song begins and ends, and how songs transition from one to the next. It's pretty freaking amazing. It was built for Windows '95 and '98. I've ran it on XP. Don't know if it would work on anything newer.
http://www.feurio.com/English/
http://www.soundonsound.com/sos/may01/arti...aheadfeurio.asp
