Hi!
Since i decided to backup my CDs and Vinyls to FLAC, i am now thinking about to catalogue it all.
My preferred export format is .txt
Well the ones i don't have a clue about how to export are:
- bit resolution (bits per sample) <- overall
- cuesheet (.cue) available [yes/no] <- in folder
- log file (.log) available [yes/no] <- in folder
I was able to find everything else i needed except these ones.
Would be super-duper-fantastic if anyone of you could help me lousy mp3tag douchebag.
Thanks in advance!
