Every time I edit and save the metadata of an m4a file, the displayed bitrate value changes unexpectedly. It seems the software is either misreading the header or altering the way the bitrate is reported after the tags are written.
I have attached two screenshots to demonstrate this:
Image 1: The original bitrate before saving.
Image 2: The modified bitrate after saving the tags
Crucially, this only happens with version 3.31. Previous versions did not exhibit this behavior.
Thank you for the update. I have tested the new version, and it seems that the issue I reported has been corrected. I will continue to use it and let you know if anything else comes up. Thank you for your help.
