While bit rate is useful for streaming, why is bit rate an option for PCM WAV files?
Can the Bit Depth (also called Bits Per Sample) be viewed and edited?
Thank you in advance.
You can find a list of available Technical information fields in the documentation.
They all can be viewed only.
(They all start with an underscore %_ and are read-only.)
You are AMAZING. I didn't realize that was available in the software. Thank you very much.
I didn't look close enough in the user manual. My fault.
