Bits per sample & Sample rate in Tag panel
I'm using Mp3tag from the App Store on macOS.
Is it possible to show Bits per sample and Sample rate in the Tag panel?
I'm currently using %_bitspersample% and %_samplerate% as columns in the file list. But I'm guessing it is not possible to show that information in the tag panel, since they are not editable?
The tag panel does not show any properties with a name starting with an underscore.
Thanks for the quick reply! Just wanted to make sure.
