- Do the mp3Tag's control panel it is possible to see the "Bit depth (Bits per sample)" (16, 24, ...)?
- Do the mp3Tag's control panel it is possible to see the codec as format: flac, ape, ogg, mp3, etc.? Instead: "Free Lossless Audio Codec libFLAC 1.2.1 ...".
It is %_extension% in the "Column Customize" ![]()
Bits per sample is not supported.
How unfortunate!
6 years have passed. Did the bit support not appear ?
From the Changelog:
[2015-11-08] NEW: added information field
%_bitspersample%for some supported file types.
