I have recently discovered your software and have to say it is what i needed big big thank you to all of you guys developing it! Thank you!
I have run into one small problem as I use a BPM detector it saves BPM info somewhere where itunes detects it and displays correctly on my mac. I can not for some reason however bet it to display in mp3tag. I'm attaching link to the file [...] for reference if you could have a look at it and tell me what am I doing wrong.
I could not see it there but I found that reason was that I marked to read both ID3 and APE tags, once I read only ID3 then the BPM comes up all right. Bit of work around but it works for me. Thx a mil!
