I upgraded to v2.43 a few months ago. Since then, the BPM field is not showing new data, but it does show previously logged information.
I don't know which version I had been using, it was at least a year old. I use MixMeister to fill the BPM field and it worked until the upgrade.
It has been a few months, but if I recall correctly, I had to add the BPM column again because it is not a default column. I think I added the column incorrectly, even though it does show some data. It just doesn't show numbers that were recently added. It is also possible that I am stripping off (or never adding) the field when I save a record because I may be using the wrong ID3 format.
The name of my column is BPM, the value is %bpm%. The FIELD and SORT BY columns are empty, but it seems to make no difference when I add %bpm% as a value.
Right now, I am reading and writing ID3v1, ID3v2, APEv2 and ID3v2.4 UTF-8 and not removing any formats.
Thanks in advance for whatever help you can offer!
