Could the Browse for Folder dialog please have a text control that allows the user to type/paste the path? I have folders with hundreds of subfolders, and having to browse the tree for the one I want is much slower.
(Current workaround: type/paste into Explorer address bar, drag n drop from folders pane to Mp3tag. Holding SHIFT for Add.)
Nice trick, seems to work!
But who had thougt of this trick at a dialog place I almost never use to go.
... so the functionality is built in, now put it at the right place in the near of the main file/folder menu.
But why on earth is a directory load control located in the tag panel??
EDIT: Esp. since the tag panel is for editing properties, and the reasonable expectation of the user is that editing the directory path will edit the directory path of the current tracks, not load the tracks at the entered path.
