From time to time I "move" a music file within my collection using mp3tag. If the file is actually a duplicate and already exists in the destination file, I get a dialogue to say Replace (the existing file in the destination) or Skip the move. If I choose "Skip" in normal Windows behaviour the file would remain in the originating directory/folder, but in Mp3tag it is deleted.
Just to make sure:
Is the file really deleted at the original file location or does it just vanish from the file list (and would re-appear if you pressed F5?
Gulp. You're quite right, it's still there. Sorry. regards Nigel.
Still better than loosing the file, I'd say.
Thank you for testing.
Thank you for reporting this issue! I've just fixed it with Mp3tag v3.25a.
