seems mp4 chapters can't be bulk stripped? Once several files are selected, the option vanishes from the context menu..please help!
Thanks.
Thanks.
As long as the selected files are MP4, the option should be available. Use the Filter via F3 to only list those: %_extension% IS mp4
They are mostly m4a, converted from flac..
Would renaming to mp4 -> stripping -> renaming back to m4a work, or is there a more elegant solution?
It's also working with M4A: %_extension% IS m4a
Like a charm, thanks! Seems I selected some mp3 together with the m4a's at first. A great app!
