The replace command in the image is not working.
Any clues why?
Thanks
I think that _FILENAME does not include the extension - this can be found in _FILENAME_EXT.
So you simply replace .flac with nothing (leave out the .mp3 in the search term).
There are different methods available to reach the goal, here are some examples.
To: Test.mp3
Convert "Filename - Filename"
Old filename pattern: %1.flac
New filename pattern: %1
Convert "Tag - Filename"
Formatstring: $replace(%_filename%,'.flac',)
Formatstring: $replace(%_filename%'.','.flac.',)
Action "Replace"
Field: _FILENAME
Original: .flac
Replace with:
DD.20180127.1200.CET
Thanks, let me try this.
thank you both
